How to input digit using push button with FPGA board?
rfub
Newbie level 6
Hi, I'm designning an electronic locker using Verilog with Xilinx 3E, Basys2 Board.
I have several problem while programming
1 I want to enter the combinations using pushbuttons, every time I push one button, the number will increase one and will be displayed on the corresponding 7-segment Led from 0 to 9.
I used FSM but I can't get the number properly, actually the simulation is good, but when I download the program into the board, the problems come out, I'm wondering if it's the reason of pushbutton?
Here's my code, can you please take a look at it and tell me what's wrong with my code? Thank you very much.
`timescale 1ns / 1ps
module Locker(clk, switch, button, cathodes, anodes, leds);
    input clk;
    input switch;//switch==0, show combination, else show locker state
    input [3:0] button;
    output [7:0] cathodes;
    output [3:0] anodes;
    output [7:0] leds;
    reg [7:0] cathodes;
    reg [3:0] anodes;
    reg [7:0] leds=0;
    reg [3:0] digit;
    reg [3:0] temp_comb;
    reg [14:0]count;
    reg [1:0] ntmp0=0, ntmp1=0, ntmp2=0, ntmp3=0, nstate=0;
    reg [1:0] ctmp0, ctmp1, ctmp2, ctmp3, cstate;
    reg [1:0] flag ;//0, unlock, 1, lock, 2, pause
    integer error=0, ledtime=0, paustime=0;
    parameter LOCK  = 3'b001,UNLC = 3'b010,PAUS = 3'b100 ;
    always @(posedge clk)  //LED flash and pause wait
    begin
        ctmp0 = ntmp0;
        ctmp1 = ntmp1;
        ctmp2 = ntmp2;
        ctmp3 = ntmp3;
        cstate = nstate;
        error <= ntmp0 + ntmp1 + ntmp2 + ntmp3;
        if (ctmp0 ==0 && ctmp1 == 0 && ctmp2 == 0 && ctmp3 == 0)
            begin
            flag = 0; //combination is right
            end
        else
            begin
            flag = 1; //lock
            end
        if (error > 30)
        begin
            flag = 2; //pause
            if (paustime > 50000000)
            begin
                paustime = 0;
                flag = 1;
            end
            paustime = paustime+1;
        end
        end
    begin
        if (flag == 2'd0 && switch == 1)
        begin
            if (ledtime > 10000000)
            begin
                ledtime = 0;
                leds = ~leds;
            end
            ledtime = ledtime+1;
        end
        else
               leds = 0;
    end
    always @(posedge clk)  //composition of combination
    begin
        case (button)
            4'b0001:
            begin
            temp_comb = ntmp0;
            ntmp0 <= #1 combination(temp_comb);
            end
            4'b0010:
            begin
            temp_comb = ntmp1;
            ntmp1 <= #1 combination(temp_comb);
            end
            4'b0100:
            begin
            temp_comb = ntmp2;
            ntmp2 <= #1 combination(temp_comb);
            end
            4'b1000:
            begin
            temp_comb = ntmp3;
            ntmp3 <= #1 combination(temp_comb);
            end
            4'b1001:
                begin
                    ntmp0 <= 0;
                    ntmp1 <= 0;
                    ntmp2 <= 0;
                    ntmp3 <= 0;
                end
        endcase
    end
    always @(posedge clk) //change of state
    begin
        case (flag)
            2'd0: nstate <= UNLC;
            2'd1: nstate <= LOCK;
            2'd2: nstate <= PAUS;
        endcase
    end
    //display the result on the 7-segment LEDs dynamically
    begin
    count <= count+1;
        if (count<=5000)
            begin
            anodes  <= 4'b0111; //an0, k14, most right segment
            end
        else if (count<=10000)
          begin
            anodes <= 4'b1011; //an1, m13
            end
        else    if (count<=15000)
          begin
            anodes <= 4'b1101; //an2. j12
            end
        else    if (count<=20000)
          begin
            anodes <= 4'b1110; //an2. j12
            end
        else
            count<=0;
    end
    always  @(posedge clk)  //displacement of the 7_segment LEDS
    begin
    if (switch == 0) //show the combinations
    begin
    cathodes = show_combination(digit);
        case(anodes)
        4'b0111: digit = ctmp0;
        4'b1011:    digit = ctmp1;
        4'b1101: digit = ctmp2;
        4'b1110: digit = ctmp3;
        endcase
    end
    else //show the clock states
    begin
            case(anodes)
        4'b0111:case (cstate) //most right anode
                         LOCK:    cathodes=8'hc6;//show nothing
                         UNLC:    cathodes=8'hc6;//C
                         PAUS:    cathodes=8'h92;//S
                    endcase
        4'b1011:case (cstate)
                         LOCK:    cathodes=8'hc0;//C
                         UNLC:    cathodes=8'hc7;//L
                         PAUS:    cathodes=8'hc1;//U
                    endcase
        4'b1101:case (cstate)
                         LOCK:    cathodes=8'hc7;//O
                         UNLC:    cathodes=8'hab;//n
                         PAUS:    cathodes=8'h88;//A
                    endcase
        4'b1110:case (cstate)
                         LOCK:    cathodes=8'hff;//L
                         UNLC:    cathodes=8'hc1;//U
                         PAUS:    cathodes=8'h8c;//P
                    endcase
        endcase
    end
    end
    function [3:0] combination;
        input [3:0] temp_comb;
        begin
            case (temp_comb)
             4'd0:    combination=4'd1;
             4'd1:    combination=4'd2;
             4'd2:    combination=4'd3;
             4'd3:    combination=4'd4;
             4'd4:    combination=4'd5;
             4'd5:    combination=4'd6;
             4'd6:    combination=4'd7;
             4'd7:    combination=4'd8;
             4'd8:    combination=4'd9;
             4'd9:    combination=4'd0;
            default: combination=8'hcf;
            endcase
        end
    endfunction
    function [7:0] show_combination;
        input [3:0] digit;
        begin
            case (digit)
             4'd0:    show_combination=8'hc0;
             4'd1:    show_combination=8'hcf;
             4'd2:    show_combination=8'ha4;
             4'd3:    show_combination=8'hb0;
             4'd4:    show_combination=8'h99;
             4'd5:    show_combination=8'h92;
             4'd6:    show_combination=8'h82;
             4'd7:    show_combination=8'hf8;
             4'd8:    show_combination=8'h80;
             4'd9:    show_combination=8'h90;
            default: show_combination=8'hcf;
            endcase
        end
    endfunction
endmodule
What problems are you getting? Can you provide the output of chipscope? How about the out of the simulation? You're not giving us a lot to work with here. As your code is, its a pain to read. If you are gonna post it in public, add comments so there can be a general understanding.
try to work with switch instead, if it works then the problem is in the pusbutton.
Thanks for your response,I've already figured out the problem.
I just went through your code it seems to be fine for me... can u tell me what is the reason behind it for not getting proper output.
Thanks
