MEAN Average or mean value.
For vectors, MEAN(X) is the mean value of the elements in X. For
matrices, MEAN(X) is a row vector containing the mean value of
each column. For N-D arrays, MEAN(X) is the mean value of the
elements along the first non-singleton dimension of X.
MEAN(X,DIM) takes the mean along the dimension DIM of X.
Example: If X = [0 1 2
3 4 5]
then mean(X,1) is [1.5 2.5 3.5] and mean(X,2) is [1 ; 4]
disp(['For the outcome of throwing a dice as: ', num2str(samples)]);
disp(['with probabilities: ' num2str(p)]);
disp(['The expected value of throwing a dice is: ', num2str(expec)]);
it works, check it out!!!
reply back!!! rpborse@gmail.com
