[SOLVED] how to get gm/id plot vs vgs in cadence virtuso
ddis
hi all,
what we get from this curve ???????
whats the interpretation????
you can refer to this URL
go to T04 small signal model
To get gm/id plot you can setup a simulation with the schematic that is showing in the following figure.
Then you must to do a parametric simulation with Vgs as variable. After this, you can use the calculator tool in order
to read the gm and id of the component.
The interpretation is the following:
gm/id is a measure of the sensitive of the device with respect to its current polarization. With the results of
this simulation you can see that as the vgs increases the gm/id decreases, in other words, the sensitive of the
device (gm) to converte voltage (vgs) into current (ids) decreases for the same current polarization.
Best regards
Reactions: MFayek
    MFayek
