How to generate a look-up table from MATLAB on FPGA in Verilog?
Amir.B
Newbie level 3
Mashhad, IRAN
hi dear all...
I have a vector consist of sine and cosine valus (A complex exponential) in MATLAB. How to generate a look-up table with this values in verilog?
I know that should be use a block-RAM, but I don't know how to write verilog code. please help me.
the values placed in a 4096×1 vector in MATLAB. I think a 4K RAM should be used, is it correct? please help...
use vhdl/verilog language templates in your system. For a example Xilinx ISE has a good set of hdl synthesis templates(counters, block ram, ...). if you know a little of verilog i will understande.
Block Dual RAM :
parameter RAM_WIDTH = <ram_width>;
parameter RAM_ADDR_BITS = <ram_addr_bits>;
(* RAM_STYLE="{AUTO | BLOCK | BLOCK_POWER1 | BLOCK_POWER2}" *)
reg [RAM_WIDTH-1:0] <ram_name> [(2**RAM_ADDR_BITS)-1:0];
reg [RAM_WIDTH-1:0] <output_data>;
<reg_or_wire> [RAM_ADDR_BITS-1:0] <read_address>, <write_address>;
<reg_or_wire> [RAM_WIDTH-1:0] <input_data>;
// The following code is only necessary if you wish to initialize the RAM
// contents via an external file (use $readmemb for binary data)
initial
$readmemh("<data_file_name>", <rom_name>, <begin_address>, <end_address>);
always @(posedge <clock>) begin
if (<write_enable>)
<ram_name>[<write_address>] <= <input_data>;
<output_data> <= <ram_name>[<read_address>];
end
---------- Post added at 16:35 ---------- Previous post was at 16:34 ----------
Pardon , "if you know a little of verilog i will understande" -> if you know a little of verilog YOU will understand )
i feel a small sarcasm in your sentence:)
Reactions: zel
    zel
No, No, Never...
Your guide was so useful for me, I say this seriously... :)
thanks, once again!
