how to forward a port to local hosts.
mashhur
Member level 5
hello everyone!
im experiencing a problem with port forwarding.
I have 2 routers hold static global IPs (given by ISP). For each routers, there are local hosts behind.
Let's say, routers' ips are R1_IPAddr and R2_IPAddr where local machines R1_IPAddr_localIP1, R2_IPAddr_localIP1 etc...
I wanna send a message from R1_IPAddr_localIP1 to R2_IPAddr_localIP1 on 5000 port.
Here is what I did:
1) went to the router setting and set the port forwarding for R1_IPAddr_localIP1 on 5000 port number.
2) created a socket binds 5000 port with R2_IPAddr_localIP1 and tries to connect to R1_IPAddr and run it on R2_IPAddr_localIP1 host.
I was supposed to connect to R1_IPAddr_localIP1 but nothing happened.
NOTE: forwarding global port 4000 where local is 5000 and also im certainly using TCP/IP connection and forward TCP port.
Please share if somebody has any ideas!
Thanks in advance.
port forwarding is done to allow incoming connections to a particular local host ip, you have done the port forwarding on the wrong router.
if you want to make a connection from R1_IPAddr_localIP1 to R2_IPAddr_localIP1 on port 5000 . then R2 should be configured for port forwarding (to R2_IPAddr_localIP1:5000)
in order to check whether the port is forwarded properly on R2 to R2_IPAddr_localIP1 , you can try to access the following website from a computer connected to R2
enter 5000 and click check
you should get port open message, provided the port is open on R2_IPAddr_localIP1, by creating a socket binds.
