sutapanaki
Can you also show your include file?
sutapanaki said:Hi,
I wish I could help you but I did this with 5.033. At work I use 4.46, however the models and simulator are not Spectre, so analog artist changes. I did a quick DC sweep using components of analogLib only. In the results browser I can see /psf -> Run1 and then the analysis I ran. So I guess you should have it too. So much for my help. You should take it from here.
v_naren said:Mon May 24, 2004.
Warning from spectre during initial setup.
`NM1': Does not have a terminal named `gm'.
Ignoring invalid item `NM1:gm' in save statement.
`NM1': Does not have a terminal named `oppoint'.
Ignoring invalid item `NM1ppoint' in save statement.
oermens said:run sp in spectre, after simulation results->direct plot->main form and you can get gm
drabos said:v_naren said:Mon May 24, 2004.
I have the same problem, with this save MN1ppoint method.
Do you have any idea, what can be the problem?
Thanks,
sutapanaki said:Can someone please explain how to plot transistor intrinsic parameters (like gm, gds, Csb,...) using Cadence Spectre? I assume that since the tool calculates these things for the operating point it should also be able to plot them as a function of time or temperature or something else.
drabos said:drabos said:v_naren said:Mon May 24, 2004.
Thanks,
Problem is solved
starcome said:drabos said:drabos said:v_naren said:Mon May 24, 2004.
Thanks,
Problem is solved
How do you solve it?
