Well if u can generate a schematic from the layout and then perform LVS .. never it will show any errors .. so the following are the steps
1) you make the layouts using candence vituso ..
2) you have to make a schematic view.
wen u start the icfb .. u can either make a new layout r new schematci .. wen u opne a new layout the tool bar will show varios metal layers ... subtrate and poly .. but wen u open a scgematic u have the options of chossing the gates r trasistors ..
so please follow soem tutorials where it shows from a small inverter ...
