liusupeng
for a multiple pole system, it will oscilate if its phase is more negative than -180 degree. if this happens, it will oscilate at the frequency where the phase is exactly -180 degree?
liusupeng said:for a multiple pole system, it will oscilate if its phase is more negative than -180 degree. if this happens, it will oscilate at the frequency where the phase is exactly -180 degree?
LvW said:liusupeng said:for a multiple pole system, it will oscilate if its phase is more negative than -180 degree. if this happens, it will oscilate at the frequency where the phase is exactly -180 degree?
No, that's not the correct description.
An active circuit of at least second order with feedback will (probably) oscillate if and only if there is one single frequency for which the loop gain (that is the gain around the open loop - not the closed loop gain) has a phase of exactly 360 deg and a magnitude of (slightly) above 0 dB.
However, this is only a necessary condition (Barkhausen criterion), but not a sufficient one. This fact often is not mentioned correctly in textbooks.
liusupeng said:Hi LvW,
Thanks a lot. so it oscillates at the frequency where the phase is exactly 360 degree?
The above description from Flatulent is 100% correct.
However, the original question was how to "determine the oscillation frequency".
And in this case it is appropriate and wise to use the loop gain vs. frequency as a criterion. Thus, you can see if and at which frequency self-sustained oscillations could occur.
Added after 11 minutes:
Yes, the phase of the loop gain (which at the desired frequency also must have a magnitude of slightly above unity).
I see at least two points:
There can't be a stationary oscillation under the said conditions. After an initial stimulation (e.g. switch-on transient, arbitrary non-zero initial condition, noise) the amplitude of the transient solution rises until it reaches a stable condition, where a more general non-linear oscillation condition can be met.
Due to the non-linear system properties, the final solution (t-> infinity) isn't necessary stationary, also the oscillation frequency must not be determined unequivocally. For a particular system with multiple oscillation frequency candidates, there's most likely a preferred frequency, but you'll have to examine the loop's complete phase and magnitude frequency characteristic to find it.
My preferred method to analyse the behaviour is assuming an initial condition and watching the differential equation solution in time domain.
As said it can't be determined without knowing the phase and magnitude characteristic and the non-linear properties of the system.the question is how to determine the exact oscillation frequency
Neither of it, most likely.is it going to oscillate at f1 or f2
