nateduong
Newbie level 3
Hi everyone,
I am a new engineer just work in the real industry, so I would like to collect more experience from the real project.
I am working on the Multipath problem, but I've not done before in the University, and really do not know how to solve it.
During the discussion from the professor which I can wrote down from the pdf file (attached below).
My responsibility: how to detect multipath?
Here are what I have?
0. Choose the simplest situation that is 1 direct signal and 1 multipath signal.
1. Center frequency of the TV station: fc = 533 MHz, and bandwidth: B = 6 MHz
2. Equation for electromagnetic: k = 2*pi/λ
3. Distance between 2 RX antennas : d1 = 10 cm (Software Define Radio with dual antenna)
4. Time delay indoor : ζ from 10 - 1000 (ns)
5. Angle θ = ± pi/2 ( everytime turn the angle pi/2 or -pi/2) (angle between RX and TX)
6. Distance between 2 RX antenna to TX antenna d2 = 4.3 km
7. Amplitude: a0 = 1 (a0 is amplitude for direct signal LOS)
a1 = [0 1) (a1 is amplitude for multipath signal 1)
8. Equation for multipath: MUL = ∑ an * exp(j*(k*(x*cosθ + y*sinθ) - w( t - ζ )))
I do not know I did right or wrong? But If anyone who has done this before, please confirm with me, I would appreciate so much.
and If I did not do right, how I can fix it. Please give me suggestions.
Thank you very much.
Code Visual Basic - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 % ***************************************************************** %%%%%%%%%%%% here is my code and plot %%%%%%%%%%%%%% % ***************************************************************** %% multipath with 2 signals : Direct signal (Light Of Sight) and reflected signal clear all; %close all f_c = 533e6; speed_of_light = 3e8 ; % m/s d = 0.01; % distance between 2 rx antenna 10cm lamda = speed_of_light / f_c; % wave length k = (2 * pi) / lamda; % notation for electro-magnetic w = 2 * pi * f_c; a = [1 1/3]; % attenuation x = [-d/2 d/2]; y = [0 0]; alpha = [0 pi/2]; % turn every time by (pi/2) tau = [0 0.1e-6]; % time delay t = 0 : (pi / 100) : (pi * 1); N_path = length(tau); % ***************************************************************** % %%%%%%%%%%%%%% simple calculation %%%%%%%%%%%%% % ***************************************************************** a0 = a(1); a1 = a(2); x0 = x(1); x1 = x(2); y0 = y(1); y1 = y(2); tau0 = tau(1); tau1 = tau(2); alpha0 = alpha(1); alpha1 = alpha(2); plane0 = x0 * cos(alpha0) + y0 * sin(alpha0); % plane1 = x1 * cos(alpha1) + y1 * sin(alpha1); % 3.417721599179047e-18 complex0 = k * plane0 - w * (t - tau0); z_Direct_signal = a0 * exp(j*complex0); complex1 = k * plane1 - w * (t - tau1); z_Reflected_signal = a1 * exp(j*complex1); z_total = z_Direct_signal + z_Reflected_signal; figure, subplot(2,2,1) plot(real(z_Direct_signal),'r') title('Direct Signal in Real'); subplot(2,2,2) plot(imag(z_Direct_signal)) title('Direct Signal in Imaginary'); subplot(2,2,3) plot(abs(z_Direct_signal)); title('Magnitude of LOS'); subplot(2,2,4) plot(angle(z_Direct_signal)); title('Phase of LOS'); figure, subplot(2,2,1) plot(real(z_Reflected_signal),'r') title('Reflected Signal in Real'); subplot(2,2,2) plot(imag(z_Reflected_signal)) title('Reflected Signal in Imaginary'); subplot(2,2,3) plot(abs(z_Reflected_signal)); title('Magnitude of Reflected'); subplot(2,2,4) plot(angle(z_Reflected_signal)); title('Phase of Reflected'); figure, subplot(2,2,1) plot(real(z_total),'r') title('total Signal in Real'); subplot(2,2,2) plot(imag(z_Reflected_signal)) title('total Signal in Imaginary'); subplot(2,2,3) plot(abs(z_Reflected_signal)); title('Magnitude of total'); subplot(2,2,4) plot(angle(z_Reflected_signal)); title('Phase of total');
