How to design an active loop filter for PLL
dicket
Junior Member level 2
active loop filter
I have two questions:
First,when I have known loop badwidth and phase margin,how to determin the components values?how to get an expression of the loop filter transfunction?
Second,how to select the OP-amp?what role does the op-amp play?what effect on PLL performance does the parameters such as INPUT RAIL,OUTRAIL and SLEW RATE make?
Thanks.
active loop filter design
For a fourth order active loop filter,How to determinate the value of C3 R3 C4 R4the higher stage of the filter?
active filter pll
Hi,for the fourth order active loop filter shown below, how to calculate the value of C3 , R3, R4? In the book ‘PLL Performance, Simulation, and Design 3rd Edition’ written by Dean Banerjee, it gives that C3=C4*4T3*T4/(T3-T4)^2 ,R3=(T3+T4)/(2*C4) , R3=(T3+T4)/[2*(C3-C4)],but I do not know how to get these formulas. Could you give me some guide or help?
Thanks.
Added after 7 minutes:
pll active filter
please reffer to
pll active loop filter
Thanks.
If you design this active filter for PLL, please care about the OP poles, this will influence the PLL own poles and zeros.
pll active loop filter design
Yes, normally the opamp poles will have an influence of 1% or even smaller.
active loop filters
note the nonlinear effect on the loop
Hi.
I think that the input bias and offset current of OPAMP is important for spures in Spectrum and the noise of opamp affect the phase noise of PLL.
