How to design a high performance DC-DC converter?
piao
Full Member level 4
about DC - DC converter
Who can give me a genral description of how to design a high performance DC-DC converter? how to decide the spec?
Re: about DC - DC converter
Search the internet for buck converter and boost converter. These two converter topologies are basic converter topologies. If you can understand these topologies it is easy for you to understand other advanced toplogies
Thanks.
Where are you using the DC-DC converter, in a low voltage application or in a high voltage application. Besides, How will you implement the circuit : on a pcb or on wafer.
Almost all information about dc-dc converters you can find in Unitrode/TI seminars:
b/rgds
You can refernce this specific
Please do not upload files available on the internet. Give link instead.
Cluricaun
8) Designing DC DC converters and power electronics is a tricky affair.
there are hundreds of types and thousands of application areas.
a non isolated converter to power simple circuits is simple to make, but if you want to develope converters for telecom application the converters not only should meet electrical specifications but also EMI/EMC, Environmental specifications etc.. the reliability of the product also comes into picture.
to start with you can read Ebbok by keith billings.(available in MCU)
Pls provide some reference for low voltage on-wafer DC-DC converter. I am looking
for a ckt for modulating the supply voltage of CMOS nonlinear PA for obtaining different
output power levels, what would be the most efficient method in terms of power/area
for doing this? The Power Amplifier works at 2.4GHz to deliver power of 100mW.
Thanks,
Saumitra
Dear Saumitra,
On chip level only the active parts can be included. the capacitors and inductors have to be placed outside because of size restrictions.
Chip level integration is possible only if you use switching frequency of some few megahertz. then inductors may be possible to be etched in silicon.
Regards.
