hurb
Newbie level 2
My clock frequency is 1MHz, so if I use clock to get 2ms delay, it will certainly take a lot of area. Does anyone have designed a long delay without clock? The accuracy of delay isn't very important.
I try to use a pretty small current (about several nA) to charge a cap to get a rising voltage, then use an invertor or comparator to get the final delayed signal. Now I am not sure whether the so small current can be implemented in IC, and whether there are any circuit to get stable and small current.
If anyone have done the similar work, please give me a hand. Thank you in advance.
