youyang
Member level 3
From a hspice (bism3/level49) lib, how everybody here to derive a hand calculating model, say, the large signal Ids model in sat/resistant area, and the small signal parameters such as Gm, Ro, etc.
The method I has been taking is to derive the indispensable parameters like U0, Cox, Vth, etc. directly from the Hspice lib file, then substitue them into the basic models based on the typical square-law.
Although this method is easily handled, it may produce large deviations when the second-order effects show up manifestly, especially with the ever-decreasing process-size.
My question is that in analog circuit design, given a process small enough, say, 0.18um, should the designer at his best abate the effects produced by short-channel-velocity-saturation by making Vov samller and L larger, so that the square-law may also valid to give us a good hand model. In other words, is the short-channel effect adverse to analog circuit and its design? Is it worth reducing its effects at the cost of a larger L?
If not, how to get a one-order model in the present of obvious short-channel effect?
any reply is appreciated! thanks a lot!
youyang
youyang
