cyberspace9
Newbie level 6
define tm
Hi
can anyone plz help me to define TM mode at HFSS.
and also how to set TM mode?
thank you
Hi
thank you
cyberspace9 said:Hi
thank you
cyberspace9 said:hi wlcsp
thanx for reply, it helps a lot.
what should i do when i need to use TM02, TM03 mode. Do i need to change waveport size? Is there any setup need to be set at hfss while changing the modes or using high order mode.
thanx
Abhishekabs said:I think when you define port there is one option
No of modes. Usually it is one. if we want more modes then we specify number.
say we want to see up TM02, TM03 then we will specify 3
Am I correct?
