How to decrease Charge Injection Error in Switches......
shady205
Full Member level 2
India Bangalore
Hello Friends..
We basically know that we can reduce using dummy transistors...
Is there any efficient way to still reduce the effect...
awaiting for your Reply's
Thanks & Best Regards
Shady205
The other not so efficient method is to greatly reduce the impedance on the driving side of the switch so that the charge distribution is unequal (more towards the low impedance node).
The clock that controls a switch connecting to the gnd(or CM voltage level) goes down a little bit earlier that the other, that often used in the SC circuit.
safwatonline said:
bottom plate sampling
Yes. Here's a short explanation:
  • bottom-plate-sampling_1291.pdf
    shady205
good and Bottom plate sampling is also can reduce it.
Added after 3 minutes:
thanks
