how to create layer stackup like this ???
kabaleevisu
Advanced Member level 2
Chennai,India
hi everyone
i have seen the board file in this board layer stack up assign. how to assign like this ???please any one help me any one
Go to Xsection.There are only two layers by default.Then right click on number coloumn below top layer.The option "Add layer below", "Add layer above" and "Remove layer" option comes.You can add any number of layers using first two options.The .jpj image file is attached for your reference
hi prastesh,
thanks for your reply. but i think your are not understand my ?? please see that file, in this board is 6 layer board file,when i click this layer stack up it is shows as
class:maufacturer
sub class :layer stack up
how it is come ??
Your image of the stack-up is just a drawing. If you want to change it you will have to copy the shapes change the text to be whateve you want but it will have no effect on the cross section of the board.
The Stack up which is shown is not Auto generated, Someone has drawn the shapes and added text to it.
You can also do the same or use the existing one as refrence and export it as subdrawing and import the same in other designs and modify as per the requirement of that design......
