How to create a VHDL library and use it.
anonymous.
Junior Member level 3
There are lots of components that are really much used in designs (Muxes,Buffers, etc). rewriting them each time or copying files from project to project is nonsense.
I want to create a VHDL library and save these components in it. I've searched about this and I can't find a good reference on this. can any body help me on creaing a library, adding files or components and using them?
No, I think you can write the component declaration inside the package declaration (not the package body).
example
package mypack is
component comp is
port
end component;
end;
package body mypack is
end package body;
and then you can instantiate the component in the top module but first write
use work.mypack.all;
in the top file where u want to instantiate the component.
Sorry I could not understand your reply, rajavel.rv . But I think you ask about how to instantiate a component in another file
You instantiate it like any other component whether the component in defined in a package or in the file itself
Anyway, you do instantiation like this
block_obj: module
port map (
