How to create a simple light dimmer using pic16f84 but without using capacitor?
yllongboy
Newbie level 6
Hi there... could somebody help me solve my problem...
I'm onto PIC programming and i wanna create a simple light dimmer using pic16f84... how is this done without using capacitor... just merely by the program... can this be done by PWM?..
Can i Have simple sample code of this?
Thank you....
Re: Light dimmer....
you want ac dimmer ?
or led dimmer ?
Hi there... thanks for the reply....
What do you mean by AC dimmer?
i dont understand it.... my problem is,
i want to light a LED with an increasing luminosity then slowly dimming.... using pic16f877.
thank you very much.... i appreciate it.....
i'll try to have a nap to it....
thanks......
You can dim a filament light bulb that's powered from the wall 110V (or 220V) 60Hz AC. The effect is similar to dimming the LED, but circuitry (as far as I understand, please correct me if I'm wrong) is more complex. By the way, I was told that fluorescent/incandescent lights powered from 60Hz AC can't be dimmed.
You might want to look at this dimmer
good luck
"AC dimmer" = AC phase Control, take a look at Light dimmer circuits
Not true. googling with dimmer flourescent, there are thousands of topics...
you will find ac dimmer in any power electonics book.
there is also direct dimmer chip is available for digital control.
