[SOLVED] How to create a footprint in Orcad ?
Re: Footprint
You first need to use Pad Designer to create the pad. Then Orcad PCB Designer Help menu should be able to help you with the rest.
Re: Footprint
Sometime its easy to make a footprint if the component is simple,but it is difficult if the component is complex.
I am attaching an orcad tutorial,may this help you.View attachment Tutorial.rar
Re: Footprint
thank you very much for the tutorial. One more help do you have the tutorial for allegro PCB Editor.
Re: Footprint
No i haven't use allegro PCB Editor, but hopefully someone here will help you about this.
Re: Footprint
Allegro PCB Editor tutorial attached.
  • algrotutorial.pdf
