oprilo
Newbie level 1
I have IC5141 and tsmc mm 0.18 PDK installed in my computer while i have not install icc11241,so i can't use virtuoso custom router to route automatic .
When i route my design manually, i confront a problem: I have to add a contact(M1_SUB) to well,which serve as the bulk node of nmos. I use "create wire"command to connect the nmos source and SUB,it doesn't works. There is no problem when i connect the pmos source and the nwell use a contact named M1_NWELL.
Can somebody here tell me how to correctly connect the bulk and the source of nmos.
Thanks
Thanks
