how to convert floating numbers in hex to use in assembly?
smartshashi
Member level 4
convert floating point to binary assembler
I am working on butterworth IIR filter & I have to implement it in ARM assembly. This filter have some fractional coefficients. Can anybody explain me how to convert this fractional coefficients in hex so that I can use it in assembly without changing the response of filter?
convert to negative floating number to hexa
smartshashi,
You can easily convert decimal fractions to hex using a calculator. Supporse you're working with 16 bit numbers.
Step 1: multiply the fraction by 65536 (2^16)
Step 2: Convert to hex. This is easy on a scientific calculator.
The result is a binary fraction with the MSB having a weight of .5, the 2nd MSB having a weight of .25, etc.
Example, convert 0.75 to hex
Step 1: 0.75 X 65536 = 49152
Step 2 convert to hex = C000 (.5 + .25)
For negative numbers, just take the 2's complement as you would for an integer. This is done by complementing all the bits and adding 1 (Throw away the carry, if any)
When you are done, of course, you must divide the result by 65536 to get the proper scaling.
Regards,
Kral
convert fixed point to hex
I think you need to konw what algorithm you want, either Fix-Point alogrithm or floating-point alogrithm, for fix-point, the above explaination is sufficient, but for floating-point, you need to convert the hex-reprensentation of your floating numbers, and again you need to designate in your assemble code that your hex nubmer is represent of floating numbers. I do not konw how to do this..
