[SOLVED] how to convert Current Pulse to Voltage Pulse?
chandlerbing65nm
Member level 5
How can I convert a (ipulse) current pulse into (vpulse) voltage pulse? I'm using ipulse in TSMC65nm in my sample and hold circuit, I want to simulate it using voltage pulse but when i directly change the ipulse to vpulse, it doesn't work so I figure out that it needs some converting.
Thank you for taking time reading this.
I think you should take the thought process further
and try to emulate the source realistically (ipulse and
vpulse both being too-ideal corners of the "box").
Things like sampling pedestal will be very much
affected by where the gate charge injection
goes, and what it meets when it gets there.
