Yes, Villard is a simple voltage multiplier the uses only diodes and capacitors, but it converts from AC to DC. If you need a DC-DC multiplier, instead, you can use a charge pump multiplier. However as already said by Rob B depends on your needs in terms of output power, ripple, etc. Regards, Alberto
