How to build an AC wattmeter?
roykyn
Full Member level 5
Full Member level 5
I need ideas to build wattmeter.I have these things in mind.
1>I have seen simple RMS wattmeter using Digital Voltmeter using the age old ICL7106/7 chip.I need proper circuit diagram.
2>The new design using Energy Metering IC with Pulse Output ICs.Sounds good but many companies produce these ICs i am in INDIA bangalore.I would like to know IC numbers available in the market.
3>using ADCs its good concept but i need analog conditioner circuit and other supporting circuits. And i also dont know how to convert AC to measurable DC.
4> ant other methods ...
ac wattmeter
Try :
AD7500 from Analog Devices.
MCP3909 from Microchip.
TMS320 microcontroler from Texas.
Just using 7107, you could not measure real consumption, due power factor may be diffrent from '1'.
ac watt meter
Some time ago, I've used the chip ADE7755 from Analog Device with very good results
