How to build a voltmeter using Pic16f887?
Re: Volt Meter Pic16f887
           [COLOR="#0000FF"]ADCResult = (ADC_Read(0) * 500) >> 10 [/COLOR]
           voltage[0] = ADCResult div 100
           voltage[1] = (ADCResult div 10) mod 10
           voltage[2] = ADCResult mod 10
           display[0] = voltage[0] + 48
           display[2] = voltage[1] + 48
           display[3] = voltage[2] + 48
     vout:
           LCD_Out(1, 10, display)
           delay_ms(50)
     wend
end.
Here what does this line mean to do
 [COLOR="#0000FF"]ADCResult = (ADC_Read(0) * 500) >> 10[/COLOR]?
its display result are VOLT (RMS Value) or VOLT (PEAK Value) ???
Hi lacoste,
I present here a simple voltmeter with 16F887 (0-5v scale). But mind it, this is very basic with no input overvoltage protection. A voltage greater than 5v applied to the input will destroy the 16F887.
Source code (written in mikroBasic):
program softwarefor887Voltmeter
dim LCD_RS as sbit at RB4_bit
    LCD_EN as sbit at RB5_bit
    LCD_D4 as sbit at RB0_bit
    LCD_D5 as sbit at RB1_bit
    LCD_D6 as sbit at RB2_bit
    LCD_D7 as sbit at RB3_bit
    LCD_RS_Direction as sbit at TRISB4_bit
    LCD_EN_Direction as sbit at TRISB5_bit
    LCD_D4_Direction as sbit at TRISB0_bit
    LCD_D5_Direction as sbit at TRISB1_bit
    LCD_D6_Direction as sbit at TRISB2_bit
    LCD_D7_Direction as sbit at TRISB3_bit
dim ADCResult as longword
dim voltage as word[5]
dim display as string[5]
sub procedure GlobInit
    ANSEL = 1
    ANSELH = 0
    TRISA = 1
    TRISB = 0
    PORTB = 0
    LCD_Init()
    LCD_Cmd(_LCD_CLEAR)
    LCD_Cmd(_LCD_CURSOR_OFF)
    LCD_Out(1, 1, "Voltage:")
    LCD_Chr(1, 16, "V")
    display[1] = "."
end sub
main:
     GlobInit
     while true
     vout:
           delay_ms(50)
     wend
end.
Hi Tahmid,
Is it really working or just for fun?
Re: How to build a voltmeter using Pic16f887
It should work. Check this image:
Try to make the circuit yourself again. If you still can't do it, I'll attach the DSN file. But it's a really simple simulation and you should be able to do it easily.
Hope this helps.
Tahmid.
Hope this helps.
Tahmid.
But this is only for meassure 5 V DC only?
Regards
Regards
Yeah, I mentioned that in the post where I gave the code. You can change the range just by scaling (for example using a voltage divider and buffer, if necessary) and adjust the code to reflect the change required in the display.
an u post hear source code [asm or hex ] file also ?
