how to blink of each bit of port in pic
thannara123
Advanced Member level 5
Usa
Hai experts i need to a program to blink led PORT1,PORT2,PORT3 etc of any port of pic 16f877a
ie i want to do blink led 's first blink led1 which is connected to PORTA of bit 0, next it connected to Porta of bit 1 ..etc
in mikroc pro
pleas help me
You can do something like
I assume that the led light with a logic 1 in the pin,
Code C - [expand]
8
9
10
11
for (i=0;i<8;i++)
 {  PORTA=(1<<i)  // 1 shifted left i times
    some delay here
PORTA=0;  // turn everything off
for (i=0;i<8;i++)
 {  PORTB=(1<<i)  // 1 shifted left i times
    some delay here
PORTB=0;  // turn everything off
you can do the rest.
also check if one of your ports has less than 8 bits (pins) and change i accordingly
Alex
thanks for reply
at last i write the program
it is working fine
thanks again
void main() {
trisa=0;
trisb=0xff;
while(1)
if(portb.f0==1)
porta=255;
else
porta=0x00;
Reactions: hdesys
    hdesys
Your code turns on/off the complete port is that what you want?
I thought you asked for the running led effect,
turn on portA bit 0 to bit7 (one at a time) then portB bit0 to bit7 etc.
Alex
Hi, I'm working hard to learn PIC 16F877A and is making LED lights on and off, controlled by the switch, can send me the code for learning purposes. Thank you.
