how much current going to pin?
sweethomela8
Member level 4
If I have 12 V going to a resistive divider series of (1.5MOhm) and parallel to ground (1.0MOhm), and I take that voltage divided output and route it to a pin...how much current is being driven to that pin?
That depends on what is the input resistance of that pin ..
Without knowing it it's a guesswork ..
IanP
:D
What if the input resistance was 10.0k...how would it be calculated? Do you interpret input resistance as a parallel resistor to ground?
You are on the right track - input resistance can be seen as a perallel reistor to ground - see attached picture ..
Formulas and calculations (incl. calculator) are here:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/voldiv.html
IanP
:D
So to calculate the amount of current going into the pin,
12 V-----> R1 --------------------------------Input resistance to ground
R2 to ground
to calculate the current into the pin, would it just be
12 V / total resistance?
total resistance = R1 + R2 || Input resistance
Thanks
sweethomela8 said:
.. to calculate the current into the pin, would it just be
Not exactly, your approach would calculate total current that flows from the power supply, your aim is to calculate that part that goes to the pin, so:
I[pin] => {U * (Rin || R2)} / {Rin * [R1+(Rin || R2)]}
:D
What is U? and can you explain how you came up with that equation?
thanks so much, im just trying to understand clearly
Equation for standard voltage divider may look like this:
[1] U[pin] = U * (Rin || R2) / [R1+(Rin || R2)]
Also:
[2] I[pin] = U[pin] /Rin ====> U[pin] = I[pin] * Rin
[1] and [2] together:
I[pin] * Rin = U * (Rin || R2) / [R1+(Rin || R2)]
And finally:
where U is the input voltage, in your case 12V ..
IanP
:D
For input resistances, you represent that by a parallel resistor to ground.
How do you represent output resistance/impedance? Is that a series resistance?
That depends on what type of source do you have in mind:
The real voltage source, such as an opamp or a battery, is molded by an ideal voltage source in series with a resistor R ..
The real current source is molded by an ideal current source in parallel with a resistor R ..
IanP
:D
What if the output is of lets say a IC, for instance the data outputs of a ADC? The data bit output can either be 3.3 V or 0V, with a output resistance X ohms. Would that be a ideal voltage source at 3.3 with a series resistance of X ohms?
