how i can implement output_b(SINE_WAVE[i]) in mikroc
khatus
Member level 3
how i can implement output_b(SINE_WAVE) in mikroc
I have found a code written in CCS C.My question is how i can implement it in mikroc
int i
CONST unsigned int SINE_WAVE[30] = {
0b00010000, 0b10010000, 0b01010000, 0b11010000, 0b00110000, 0b10110000,
0b01110000, 0b11110000, 0b01110000, 0b10110000, 0b00110000, 0b11010000,
0b01010000, 0b10010000, 0b00010000, 0b11100000, 0b01100000, 0b10100000,
0b00100000, 0b11000000, 0b01000000, 0b10000000, 0b00000000, 0b10000000,
0b01000000, 0b11000000, 0b00100000, 0b10100000, 0b01100000, 0b11100000};
main()
for(i=0;i<30;i++)
output_b(SINE_WAVE[i]);
Here how i can implement output_b(SINE_WAVE); function in mikroc
i want to convert this code to mikroc
#include <16F88.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP,PUT,CCPB3
#use delay(clock=8000000)
int i, j;
#INT_RTCC
void main_wave() {
    if (i++ == 29)
        i = 0;
#INT_TIMER2
void TIMER2_isr() {
    if (j++ == 29)
        j = 0;
    output_a(SINE_WAVE[j]>>4);
void main(void) {
    i = 0;
    j = 0;
    setup_adc_ports(NO_ANALOGS);    // Turn off analogue inputs
    setup_oscillator(OSC_8MHZ | OSC_INTRC);   // Use internal 8MHz osc
    set_timer0(0);
    setup_counters( RTCC_INTERNAL, RTCC_DIV_1 | RTCC_8_BIT);
        // about 258.7Hz
        setup_timer_2( T2_DIV_BY_4, 65, 1 );
        // 65 gives 250.8Hz
        enable_interrupts(INT_TIMER0);
        enable_interrupts(INT_TIMER2);
    enable_interrupts(GLOBAL);
    while(TRUE)
        delay_ms(1);
        disable_interrupts(INT_RTCC);
I only know standard C, but I think the output_a is just a function to send the values of the table to a single pin. You can use either bit banging or another serial protocol to send the value out!
No. It's a build-in compiler function sending an 8-bit number to port A pins. The code assumes a 8-bit parallel DAC connected to the port.
... wouldn't that just output the upper 4 bits of the value and ignore the lower one?
I'm not familiar with MikroC, it doesn't run on my OS but periodically reading a table and sending its contents to a port is hardly rocket science.
Yeah, that what I thought too!
Sending or receiving data from port to another is one of the first step you learn in microcontroller world!
The problem, that so many people don't take the time to learn things from the ground up! And, that's why they use compilers that do most of the job for them, unlike assembler or standard C!
hello,
where is the init of PORTA ?
TRISA=0;
PORTA=(SINE_WAVE[j]>>4);
look at this 16F88 MikroC version ... not tested
  • 16F88_example.c.txt
In the original code and the 16F88 example only four bits are used. The '>>4' part of the code just moves the upper bits to the lower bit positions. How that is used in the circuit depends on how the DAC is wired. If you really only want to use 4 bits, change the look up table and then you can omit the bit shift in software.
Note that a 4 bit sine wave only has 16 levels so it will look more like a staircase than a smooth curve. As all the port bits are used, why not also increase accuracy by using all the bits in the look-up table?
you defined timers by frequency ! it is not usual
Timers are defined by time units !
so i started ,in my example , with 4mS periode for timers (because ~250Hz indication)
in this case , to explore the 30 steps => 30x4=120mS
it means Sinus defined for 8.33Hz
This frequency output is enough low to use
=> PWM instead of DAC ....
Other MCU , as PIC16F1615-16F1619 has a 8 bits DAC output 256 levels
18F26K22 5bit DAC outputs 32 levels
