How do I plot Id vs VDS for different VGS in Hspice?
suhas_shiv
Full Member level 2
Hi all,
I am a beginner to Hspice. I want to know the command to plot the current vs voltage curve for a transistor. I mean, how do I plot Id vs VDS for different VGS in Hspice?
Thanks
Re: Hspice Help
Hello suhas_shiv
You should define printing the current, for example.
> .print dc i(mm0)
When mm0 is your transistor name in the netlist.
and during definition of the dc analysis you can use sweep function., for example:
.dc vds 0 5 0.01 sweep vgs 0 5 0.5
Regards,
Dmitry
Re: Hspice Help
Use Avanwave,
Easy
Re: Hspice Help
Check the manual, for the current there are special symols for Ids/Igs etc. So you need to save them and then plot
