A
ahmadagha23
I read that for doing a pss analysis in spectreRF except clock other signals (including input) should be zero. now if I want to do at first a PSS analysis and then based on its data do a PAC analysis for a circuit, what is the detailed procedure? please say each step in detail for SPECTRERF environment.
For the above procedure is there any difference between spectreRF2008 and earlier?
What is the difference between fundamental tones and beat frequency in spectreRF 2007? Should I set them simultaneously?
Is there any project file (files themselves) in spectreRF for doing pss and pac specially for switched capacitors?
Regards
Regards
