How can i simplify this function?
otuzsubat
Member level 4
istanbul, Turkey
I use a 4x3 keypad in my project. I use C0, C1, C2 and C5 pins as output, and E0,E1,E2 as inputs. Can this function be more simply?
char one_char(void){
unsigned int row;
for (row=0; row<4;row++){//"row"
if (row==0){
output_low(pin_c0);
output_high(pin_c1);
output_high(pin_c2);
output_high(pin_c5);
if (row==1){
output_high(pin_c0);
output_low(pin_c1);
if (row==2){
output_low(pin_c2);
if (row==3){
output_low(pin_c5);
if(!input(PIN_E0)&&input(PIN_E1)&&input(PIN_E2))
return((row*3)+1+0x30;
else if (input(PIN_E0)&&!input(PIN_E1)&&input(PIN_E2))
return((row*3)+2+0x30);
else if (input(PIN_E0)&&input(PIN_E1)&&!input(PIN_E2))
return((row*3)+3+0x30);
else
return(0);
Wouldn't help much to simplify it, since human fingers are very much slower than the uC.
Anyway, assuming that the other pins of port C are not output pins, you could simply output 0x17 to port C at the end of the for loop, instead of having so many output_high. (Provided you disable CCS's auto-TRIS setting of course)
When testing for columns, if you can ensure that the user only presses one key at a time, you can just test for that single pin.
Try using row+row+row or row+=(row<<1) instead of row*3.
BTW, have you tried the code before? Do you have an external switch debouncing circuit? Because it's not done in software.
Cheers!
I use the other pins of C. In fact, i want to know how i can set or clear some pins at one time without changing the other pins.
Meanwhile, i applied your sugestion and my function runs faster now.
I will add codes for debouncing, but before this i want to reduce the size of function.
You can do some tricks .
As example for return part :
change
else
return(0);
to :
const unsigned char conversion[8] = {0,0,0,1,0,2,3,0};
return (conversion[input(port_E)&0x07] == 0 ? 0 : (conversion[input(port_E)&0x07] + 0x30 +row*3));
Did not check for correctness, but concept is OK .
Assuming that you can output to all four bits of port c in one output operation, you could change from row++ between loops, to row<<=1, and output the bit-wise inverse of row onto port C:
for ( row = 1 ; row < 32 ; row <<=1 )
output( port_c, ~row )
The keycodes returned change, but you presumably have code to convert keycodes to digits (or whatever is on the key), so this could be adapted.
HTH
Barny
I changed my function as below. I seperated it to two functions.
The basic changes are i dont use "for" loop for the variable "row" and instead of return((row*3)+3+0x30); i use tus_degeri=(row+=(row<<1)+0x33);
char tus_degerlendir(unsigned int row){
byte tus_degeri;
if(!input(PIN_E0)&&input(PIN_E1)&&input(PIN_E2)){
tus_degeri=(row+=(row<<1)+0x31);
if(tus_degeri==0x3A)
tus_degeri=0x2A;
return (tus_degeri);
if (input(PIN_E0)&&!input(PIN_E1)&&input(PIN_E2)){
tus_degeri=(row+=(row<<1)+0x32);
if(tus_degeri==0x3B)
tus_degeri=0x30;
if (input(PIN_E0)&&input(PIN_E1)&&!input(PIN_E2)){
if(tus_degeri==0x3C)
tus_degeri=0x23;
return (0x00);
char tus_tara_degerlendir(void){
byte temp,row;
row=0;
output_low(pin_c0);
temp=tus_degerlendir(row);
if (temp!=0)
return (temp);
row=1;
output_low(pin_c1);
if (temp!=0)
return (temp);
row=2;
output_low(pin_c2);
if (temp!=0)
return (temp);
row=3;
output_low(pin_c5);
if (temp!=0)
return (temp);
return(0x00);
You could also set all the output pins high then select which one to set low with a case statement.
But for this program that mostly saves typing. It may also be more compact code, but thats not always so when the number of cases is small.
After setting the pin_c ports to known state at the start of the function, you only have to write to the ones that change:
byte temp,row;
row=0;
output_low(pin_c0);
if (temp!=0)
return (temp);
row=1;
output_low(pin_c1);
// NOT NEEDED output_high(pin_c2);
// NOT NEEDED output_high(pin_c5);
if (temp!=0)
return (temp);
row=2;
// NOT NEEDED output_high(pin_c0);
output_low(pin_c2);
if (temp!=0)
return (temp);
row=3;
// NOT NEEDED output_high(pin_c1);
output_low(pin_c5);
if (temp!=0)
return (temp);
return(0x00);
