How can i calculate the bandwidth of IF filter in receiver?
aamir sher khan
Newbie level 2
band with requirment
hi
I am using FSK technique to transmit data through air using RF.The data rate is 50Kbps and Frequency deviation is 90KHz.The receiver uses phase lock loop PLL method to demodulate the signal.Can anyone tell me how can i calculate the bandwidth of IF filter in receiver.Does the PLL method reduces the bandwidth requirement.
IF band width requirment
Yes, but according to the source, the bandwidth rule applies to GFSK rather than simple FSK.
Re: IF band width requirment
i am using BFSK and the carson rule for that is
B = 2 * ( frequency deviation + symbol rate )
do you think that this rule is not applicable so FSK
I think, you should calculate some overhead rather than designing the bandwidth too small.
P.S.: Or accept a smoothening of the received waveform. You have to consider also the modulation, e.g. manchester or direct coding.
