wini-1
Junior Member level 2
Hi there
I have a stepper motor that appear in the picture below (it labeled with 1.8A ), and it's coil resistance is : r = 3 [ohm].
I want to use a transistors to drive this motor like the schematic in picture 2. [ the transistors are ( MJE3055T ), data sheet is appear below ] .
my questions are :
1. If i want to run this motor at [ 12v & Ic = 1.5A ] , How can i calculate the correct value of Rc and Power Dissipation of it [watt] ?.
and how can i calculate the value of Rb ?
2. what is the difference if i use 24v in place of 12v ?.
3. What is the role of (Rc) here ? Is it for limit the current at the value which we needed (Ic = 1.5A) OR to pull the needed value of current (Ic = 1.5A) from the power supply??
Can any one explain the way to achieve that?
THANX FOR ALL.
my questions are :
THANX FOR ALL.
