EzPCB-Nila
Member level 3
Enclosure BZ3608C 361X85X270MM aluminum enclosure
Outside Dimension: W x H x L = 361mm x 85mm x 270mm(14.17''x3.35''x10.63'')
Inside Dimension: W x H x L = 280mm x 74mm x 256mm(11.02''x2.91x10.08'')
Material: Aluminum
Finish: Brushed, hard anodized
Net Weight: 3kg
Accessories: a power switch 4A250V
2 pcs 38 mm aluminum knob
1set 30 mm aluminum machine feet with rubber shock absorber
1piece a Insured power supply base
Material: Aluminum
Net Weight: 3kg
