vterminater
Junior Member level 1
I just have one question in the equation mentioned. I understand the equation for setup given above but what I don't understand is that for hold clock time period should not matter right. According to me the equation for hold should just be
Tc-q + Tcomb > Tskew+ Thold
This is because even in single cycle timing clk period is not considered for hold calculation. Is this a special case for half cycle timing?
Thank you for the detailed explanation.
Did you mean the amount of time the data must be stable 'after' the clock ?
I understand that,
launch path = Tc-q + Tcomb
but what is capture path component in the equation ? Is this the skew ? If yes, then here is the final equation. Let me know if they are correct.
Tclk/2 + Tskew >= Tc-q + Tcomb + Tsetup
Tclk/2 + Tc-q + Tcomb >= Thold + Tskew
