shanishp
Newbie level 6
Hi.
I have interfaced Honeywells HMC 5843 compass with PIC 16F877A in single supply mode,The problem is that LCD display connected to the same is showing heading angle as 360 and 180 degree, no further angle is obtaining,please help me any one having more experience with this IC.
I am attaching my c program with this
#include<pic.h>
#include<math.h>
#include"877_i2c.h"
#include"delay.h"
#include"lcd.h"
__CONFIG(HS & WDTDIS & LVPDIS & PWRTEN & PROTECT);
#define one_eighty_by_pi 57.29577
#define PORTBIT(adr, bit) ((unsigned)(&adr)*8+(bit))
//static bit @ PORTBIT(PORTB, 1);
void write_HMC5843(unsigned char,unsigned char);
void read_HMC5843(unsigned char);
void write_HMC5843_new(void);
unsigned int heading;
signed int mag_x,mag_y,mag_z;
double angle;
unsigned char lcd_val,stat,vl;
void main()
TRISA=0;
TRISB=0;
TRISC=0;
TRISD=0;
TRISE=0;
TRISC3=0;
TRISC4=1;
ADCON1=0X07;
PORTA=0;
PORTB=0;
PORTC=0;
PORTD=0;
PORTE=0;
heading =0;
i2c_init();
lcd_init();
lcd_clear();
lcd_goto(0);
lcd_puts(" HMC 5843 ");
lcd_goto(0x40);
lcd_puts("Heading : "); //4B
DelayMs(150);
//write_HMC5843_new();
write_HMC5843(0,0x10); // Configuration register A : set default value
write_HMC5843(1,0x20); // Configuration register B : set default value
write_HMC5843(2,0x00); // Mode Selection : continous mode selected
DelayMs(950);
while(1)
read_HMC5843(0x03);
angle=(double)(mag_x/mag_y);
if((mag_y<0) && (mag_x>0))
heading=(unsigned int)(atan(angle));
else if((mag_y<0) && (mag_x<0))
heading=(unsigned int)(360-atan(angle));
else if((mag_y>0) && (mag_x<0))
heading=(unsigned int)(180+atan(angle));
else if((mag_y>0) && (mag_x>0))
heading=(unsigned int)(180-atan(angle));
lcd_goto(0x4B);
lcd_val=(heading/100)+48; // 128 1
lcd_putch(lcd_val);
lcd_val=heading%100; // 28
lcd_val=(lcd_val/10)+48; // 2
lcd_putch(lcd_val);
lcd_val=heading%100; //28
lcd_val=(lcd_val%10)+48; // 8
lcd_putch(lcd_val);
// lcd_puts(" ");
// i2c_start();
// i2c_write(0x3C);
// i2c_write(0x09);
// i2c_repStart();
// i2c_write(0x3D);
// stat=i2c_read(0);
// i2c_stop();
// if(stat & 0x01)
// lcd_puts("1");
// else
// lcd_puts("0");
// lcd_puts(" ");
// if(stat & 0x02)
// lcd_puts("1");
// else
// lcd_puts("0");
DelayMs(950);
void write_HMC5843(unsigned char address,unsigned char data)
i2c_start();
i2c_write(0x3C);
i2c_write(address);
i2c_write(data);
i2c_stop();
DelayMs(15);
void read_HMC5843(unsigned char addr)
i2c_start();
i2c_write(0x3C);
i2c_write(addr);
i2c_repStart();
i2c_write(0x3D);
mag_x=i2c_read(1);
mag_x=(mag_x<<8)+i2c_read(1);
//heading=mag_x;
//lcd_goto(0x10);
//lcd_val=(heading/100)+48;
//lcd_putch(lcd_val);
//lcd_val=heading%100;
//lcd_val=(lcd_val/10)+48;
//lcd_val=(lcd_val%10)+48;
//lcd_puts(" ");
mag_y=i2c_read(1);
mag_y=(mag_x<<8)+i2c_read(1);
//heading=mag_y;
//lcd_puts(" ");
mag_z=i2c_read(1);
mag_z=(mag_x<<8)+i2c_read(0);
//heading=mag_z;
//lcd_puts(" ");
i2c_stop();
i2c_start();
i2c_write(0x3C);
i2c_write(0x02);
i2c_write(0x00);
i2c_stop();
DelayMs(15);
#include<pic.h>
#include<math.h>
#include"877_i2c.h"
#include"delay.h"
#include"lcd.h"
double angle;
void main()
TRISA=0;
TRISB=0;
TRISC=0;
TRISD=0;
TRISE=0;
TRISC3=0;
TRISC4=1;
ADCON1=0X07;
PORTA=0;
PORTB=0;
PORTC=0;
PORTD=0;
PORTE=0;
heading =0;
i2c_init();
lcd_init();
lcd_clear();
lcd_goto(0);
lcd_goto(0x40);
DelayMs(150);
DelayMs(950);
while(1)
read_HMC5843(0x03);
lcd_goto(0x4B);
lcd_putch(lcd_val);
lcd_putch(lcd_val);
lcd_putch(lcd_val);
// lcd_puts(" ");
// i2c_start();
// i2c_write(0x3C);
// i2c_write(0x09);
// i2c_repStart();
// i2c_write(0x3D);
// i2c_stop();
// if(stat & 0x01)
// lcd_puts("1");
// else
// lcd_puts("0");
// lcd_puts(" ");
// if(stat & 0x02)
// lcd_puts("1");
// else
// lcd_puts("0");
DelayMs(950);
i2c_start();
i2c_write(0x3C);
i2c_write(address);
i2c_write(data);
i2c_stop();
DelayMs(15);
i2c_start();
i2c_write(0x3C);
i2c_write(addr);
i2c_repStart();
i2c_write(0x3D);
mag_x=i2c_read(1);
//heading=mag_x;
//lcd_goto(0x10);
//lcd_puts(" ");
mag_y=i2c_read(1);
//heading=mag_y;
//lcd_puts(" ");
mag_z=i2c_read(1);
//heading=mag_z;
//lcd_puts(" ");
i2c_stop();
i2c_start();
i2c_write(0x3C);
i2c_write(0x02);
i2c_write(0x00);
i2c_stop();
DelayMs(15);
