carpenter
Full Member level 6
Hello
I need measure high voltate , for example 1kV - 8kV ,
if use 50M compensated high voltage resistor divider will be on
8kV current over divider 160uA and Power disipation 1,3W
1kV current over divider 20uA and Power disipation 20mW
The question is in which current the resistive divider works OK and at what already leaked currents cause an error, which also prevents the indicative measurement (error is over 5 or 10%)
