ctownsend said:Why don't you draw a simple schematic so others can see what you have done, and maybe offer some help.
betwixt said:Assuming you are switching unipolar (not below ground voltage) and at low speed it should work. The only pull-up or pull-down you might need is on any input that should not be allowed to float. Note that a 4053 channel is high impedance when switched off and this could cause a floating condition.
Brian.
