Where is the output node? There isn't one on the diagram. Also, what is on the other side of the inductor?
As it stands, it isn't possible to simulate it
Brian.
The circuit is obviously intended as supply switch with the LNA as a load. For getting non-meaningless simulation results, you have to place at least a resistor representing the load, e.g. 1K. Then you can expect to see the switch operation.The other side of the inductor is a LNA,so what the voltage of the LNA?
