ccarrot
Newbie level 6
I'm going to design a phase shifter (or called phase tuner) with 0-90 degree tuning range. It works between 100MHz-200MHz, i.e. the input signals are two quadrature digital inputs with f=100-200 MHz.
I checked a lot of references, but they usually works at RF band. I tried a current-steering topology (as shown below), but i'm not able to make it work I think it is because 100-200 MHz is very low.
Is anybody can help me out?
(1) Will current-steering topology work at 100-200MHz?
(2) Any circuit advised?
Thank you!
![xx.png xx.png](https://www.edaboard.com/data/attachments/38/38508-f04b0dde3e0c1af39f85d373194654d9.jpg)
Thank you!
