help with pic16f877a Serial Communication programming using assembly language MPLAB
luigi_moran23
Newbie level 5
Hi! Is there someone out there who can help with my problem? My problem is I want to send a number from the computer to pic16f877a using assembly language program and vice versa . I am also want to use the pickit2 as a UART. Was this possible? If possible, can you at least send me a program that does like this in assembly language: RB0 will on if "1" is sent from computer to microcontroller, and RB1 if 5V is apply the computer will recieve a "2" coming from the microcontroller. Please Help me. Thanks.:)
Yes you can do it with Assembly and you can use your Pk2 Usart Tool to act as the PC terminal.
You first have to know what frequency crystal you are using the the 877A, this is because the Usart has to be set up based on that.
You can learn how to use the Usart in this tutorial , the last entry 7.7 is based on the 876/877A chip so it should work ok if you adjust it for your crystal.
http://www.winpicprog.co.uk/pic_tutorial7.htm
If you are stuck post the code you have done detailing what the problem is.
Below is a screen shot of my 18F code working the Usart tool.
You can use this program to test your hardware / Pk2 USART Tool
It connects to your Usart port , and when a '1' is sent to the pic , portC,0 turns on for 4 seconds. All other characters are ignored.
Based on a 4 mhz crystal.
  • usart.zip
