So, is there actually no equation in order to design the dimension of the microstrip line??
The width of the microstrip line (Wf in your picture) is given by the line impedance (usually 50 Ohm).
The slot width (equal to Wf in your picture) should not be critical.
Isn't that a different case, with probe feed instead of line feed from the side?
does it matter the length of the line or its width?
can someone tell me EXACTLY how to design the connection between the generator and the antenna??
Can you help me out with the "electrical length" parameter??
ok, but I need anyway to put a value...
Ok...so let me put this straight.. I have a patch antenna that I want to feed with a microstrip line.
The output of my generator is at 50 Ohm.
I already calculated the value of all the parameter of the antenna, I just need the microstrip line!!
