help needed with setting prescaller for ATmega 32
joephie
Newbie level 5
in ur heart
[HELP] precise 1 second
can anyone help me calculating the prescale for ATmega 32 on Timer1 with crystal 11.0592 MHz. I'm using BASCOM but i don't know what is the prescale to make precise 1 second.
thank you
Re: [HELP] precise 1 second
Set the prescaler to 1024 and keep a 16bit counter in the interrupt routine to count to 10800(0x2a30), which will be 1 second exactly.
Yes do what bosparra said.
Use the compare module to count upto 10800 and then clear timer on compare (CTC) and generate interrupt on compare match.
i'll give it a try guys.. but i have another problem on enabling the crystal. could anyone help setting up the fuse bit... wich part i should select? ? [CKSEL SUT CKOPT]
Set the fuse bits as:
CKOPT: 0(PROGRAMMED)
BOOTRST: 1(UNPROGRAMMED)
CKSEL3: 1(UNPROGRAMMED)
CKSEL2: 1(UNPROGRAMMED)
CKSEL1: 1(UNPROGRAMMED)
CKSEL0: 1(UNPROGRAMMED)
SUT1: 0(PROGRAMMED)
SUT0: 1(UNPROGRAMMED)
Hope this helped.
Tahmid.
thank you very much for the help... but now im waiting the electricyti, it has been black out since yesterday ....oh my
are you from Iraq :cry:
this is my code
$regfile = "m32def.dat"
$crystal = 11059200
Config Timer1 = Counter , Edge = Falling , Prescale = 1024
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = Porta.2 , Db5 = Porta.3 , Db6 = Porta.4 , Db7 = Porta.5 , E = Porta.1 , Rs = Porta.0
Cursor Off
Stop Counter1
Dim Speed As Long
Dim Speedo As Long
Cls
Do
Counter1 = 0
Start Counter1
Waitms 1000
Stop Counter1
Speed = Counter1
Speed = Speed * 1000
Speedo = Speed / 2
Locate 1 , 1
Lcd "pulse: " ; Speedo
Lowerline
Lcd "Rotation perminute"
Waitms 250
Loop
End
how would i know if my sistem is already running at precise 1 second.....
That code seems to be written in BASCOM, am I right?
I use mikroBASIC and the codes look quite different. So I can't help you.
ouh, is there anyone can help....its been a headache to select the prescaler
