Help needed with ATmega Multi Processor Communication
drtvskuthsav
Hey guys,
I need some help with MPCM in ATmega32. I tried this mode with two microcontrollers on PROTEUS. The master is transmitting the data, but the slave is not receiving the correct data. I tried this mode with 9bit as recommended in atmega32 datasheet. I am posting code for both master and slave. Please do help me in solving this.
Baud rate=9600
Freq=8MHz
Circuit diagram is attached.
/*****SLAVE_CODE*****/
//* KUTHSAV*//
//*Including Header Files Required*//
#include <mega32.h>
#include <stdio.h>
#include <stdlib.h>
#include <delay.h>
#include <string.h>
//*Declaring LCD PORT as PORT A*//
#asm
    .equ __LCD_PORT=0x1B; PORTA
#endasm
#include <lcd.h>
#define baud 0x33 /* Baudrate=9600 at 8Mhz IRC Oscillator*/
#define UCB 0xDC /*Enabling TXIE, RXIE TX and RX in 9bit*/
#define rxb 1
#define slave_address 0x01;
/*Declaring Global Variables*/
unsigned char si=0,qi=0,i=0,p=0,j=0,k=0,l=1,g=1,n=0,m=0;
unsigned char z;
unsigned char dl=2000;
char flag;
//char *cmd=NULL;
//char *msg=NULL;
char q[160];
char ch1[60];
char ch2[30];
char ch3[30];
char ch4[6];
char ch5[5];
char control,status,data;
void usart_init(void)
        UCSRA=0x01;
        UCSRB=UCB;
        UCSRC=0x06;
        UBRRH=0x00;
        UBRRL=baud;
interrupt [USART_TXC] void usart_transmit_isr(void)
        if(qi!=si)
            UCSRB&=(~(0X01));
            UDR=q[si++];
interrupt [USART_RXC] void rx_isr(void)
    status=UCSRA;
    control=(UCSRB&(1<<rxb));
    data=UDR;
   // lcd_putchar(data);
    if(status&(0x01)==1)
            UCSRA&=(~(0x01));
            lcd_putchar('o');
    else
        lcd_putchar(data);
void main(void)
lcd_init(16);
//delay_ms(10);
#asm("sei")
usart_init();
    while(1)
/*****END_SLAVE_CODE*****/
/*****MASTER_CODE*****/
//?MultiProcessorCommunication?//
//* KUTHSAV*//
#include <mega32.h>
#include <stdio.h>
#include <stdlib.h>
#include <delay.h>
#include <string.h>
#asm
#endasm
#include <lcd.h>
#define baud 0x33; /* Baudrate=9600 at 8Mhz IRC Oscillator*/
#define UCB 0xDC; /*Enabling TXIE, RXIE TX and RX in 9bit*/
unsigned char z;
char flag;
//char *cmd=NULL;
//char *msg=NULL;
char q[160];
char ch1[60];
char ch2[30];
char ch3[30];
char ch4[6];
char ch5[5];
char ch,ph;
        UCSRA|=0x00;
        UCSRB|=UCB;
        UCSRC=0x06;
        UBRRH=0x00;
        UBRRL=baud;
        if(qi!=si)
            UCSRB&=(~0x01);
            UDR=q[si++];
void send_address(unsigned char slave)
        UCSRB|=0x01;
        UDR=slave;
        delay_us(1000);
        UCSRB&=(~0x01);
void send_data(char *s)
     qi=0;
    si=1;
    while(*s)
            q[qi++]=*s++;
UDR=q[0];
    ch=UDR;
void main(void)
#asm("sei")
lcd_init(16);
usart_init();
send_address(0x01);
send_data("Kuthsav");
while(1)
/*****END_MASTER_CODE*****/
Kuthsav Thattai
did you check it in 8 bit mode?
I tried this, code too....
Still getting corrupt message..
//* KUTHSAV*//
#include <mega32.h>
#include <stdio.h>
#include <stdlib.h>
#include <delay.h>
#include <string.h>
#asm
#endasm
#include <lcd.h>
#define rxb 1
unsigned char z;
unsigned char flag=0;
//char *cmd=NULL;
//char *msg=NULL;
char q[160];
char ch1[60];
char ch2[30];
char ch3[30];
char ch4[6];
char ch5[5];
        UCSRA|=0x01;
        UCSRB|=UCB;
        UCSRC|=0x06;
        UBRRH=0x00;
        UBRRL=baud;
        if(qi!=si)
            UCSRB&=(~(0X01));
            UDR=q[si++];
    if(flag==0)
    status=UCSRA;
    data=UDR;
    if((UCSRA&0x01)==1)
          if((control>>1)==1)
                UCSRA&=(~(0x01));
                UCSRB=0xD8;
//                lcd_putchar('o');
                flag=1;
                return;
    else if(flag==1)
        data=UDR;
        lcd_putchar('i');
        lcd_putchar(data);
         return;
void main(void)
lcd_init(16);
//delay_ms(10);
#asm("sei")
usart_init();
    while(1)
I don't think there is some problem with the master. Only slave.
Can you post the 2 hex files and proteus .dsn file. zip and post it.
I got this error. Please post the complete project files zipped.
----------------------Update---------------
I t shows kuthsav. Should the slaves read the data Kuthsav and display it on lcds?
Yes it should read the data 'Kuthsav' and display it on lcd. I'll upload complete project files zipped to night.
Kuthsav Thattai
lcd data was not correct ascii value. I think data is missing in communication.
The complete project is uploaded. Please try to find the bug and help me in fixing it.
Kuthsav Thattai
  • mpcm_2.rar
Thank You all for trying to help me...The problem is solved. I still have a doubt.
I tried using slave device design on new .dsn file. And I used COMPIM component and connected it to microcontroller. So I run the simulation of the slave design and then the master design. I got the output when I changed the COMPIM setting as shown in the attached figure(Just tried trail and error).
Now my doubt is why this did not work when we connected master and slaves directly??
