neferet
Junior Member level 1
Hi all,
I have to make a simulation and then the fabrication of a microstrip filter (at 1, 1.5 or 2GHz). I have decided to make an edge coupled bandpass filter(it may be something else) by using Ansoft Designer SV. However, my substrate is not in the Designer. So, I first make a filter by using the filter tool and then I change the permitivity. However, I cannot add the loss tangent when I am inside the filter tool. When I add it afterwards, the response does not look as before(as usual). This time I try to optimize it by changing the dimensions by myself (because I think SV does'nt have tuning property), but I end up with 400-500MHZ bandwidth and 2.5dB loss at the center freq. Is this so unsual at this frequency or am I able to cope it by another way. Any decision?
Thanks...
Thanks...
