Help me with designing a s band VCO
ahmer saeed
Member level 1
s band vco
I want to design s band vco. If the source and terminating network of local oscillator is design using transmission line and stubs without using discrete components ,Can it be change to vco by inserting varacter diode?
Can VCO can only be design using discrete component?
Please tell me a good book which guide me in designing VCO.(Practical approach)
Re: s band vco
Try V844ME02:
Description:
Package Style = MINI-14S-L ;; Frequency (MHz) = 3430 to 3610 ;; N@10KHz (dBc/Hz) = -88 ;; Tuning Voltage (Vdc) = 0.50 to 4.50 ;; Tuning Sensitivity (MHz/V) = 87 ;; Power (dBm) = 2.25 ± 1.25 ;; Op.temp ( C) = -40 to 85 ;; VCC (Vdc) = 5.00 ;; Icc (mA) = 18
Data sheet attached ( here is the link but you will have to register .. https://www.digchip.com/ )
For application notes you will have to contact manufacturer .. contact numbers in Data Sheet ..
Re: s band vco
First of all, do a search on EDABOARD for "oscillator and design", you will find valuable topics.
Some good books are (among others):
1.Randall W. Rhea : "Oscillator Design and Computer Simulation", ISBN l-8849-32-30-4, Noble Publishing Corporation
2.Vendelin/Rohde/Pavio : "Microave Circuit Design using Linear and Nonlinear Techniques", ISBN 0-47 1-60276-0, John Wiley and Sons
3.Michal Odyniec : "RF and Microwave Oscillator Design", IBN 1-58053-320-5, Artech House
4. Peter Vizmuller: "RF Design Guide
Look also for someAlphaIndusties/SkyWorks appnotes about oscillators:
hxxp://www.skyworksinc.com/products_search.asp?DocType=38&FindByKey=Go&KeyWord=&SearchWhere=PDFfiles
(change the xx to tt)
regards,
Al
s band vco
one way is let the indoctor replace by the transmission line.
or you may use the method of negative impedance to design.
