kokei74
Junior Member level 3
square-root nyquist using simulink
Hi, i try to implement a QPSK modulator using simulink. This is a expected result of the modulator where im using a QPSK block in library.
As for my own build here is the model of the QPSK block. But there is an error at Root Raised Cosine Filter block. Is im missing some parameter or others input i need to put in? If that Root Raised Cosine Filter block is not included the the eye diagram and scatter diagram is not display correctly but for the waveform its display correctly. Here is the figure of QPSK block i have create.
i also have attached model files of both model. Can someone pls tell me what is the problem of my design and how to fix this??
