Help me to lower the clock of verilog code
moonnightingale
Full Member level 6
Hi i have written a code which is working fine in simulation.
When i burn it on my FPGA kit Spartan 3E, i am unable to see the effect due to very high clock.
Its clock is 50 MHz which comes to be 2x10(-8) seconds
I want this clock timing to be 5 seconds which means 0.2 Hz.
How can i do that ?Is some change required in UCF??
Plz Guide me
this is my code
module statediagram(y_out,x_in, clock, reset);
output [1:0] y_out;
input [1:0] x_in;
input clock,reset;
reg [1:0] y_out;
reg [30:0] count;//
reg[1:0] state,next_state;
parameter S0=2'b00,S1=2'b01,S2=2'b10,S3=2'b11;
always@(posedge clock,negedge reset) // The negedge reset event is asynchronous since it matches the
//if(~reset) statement
if (reset==0)state<=S0;
else state<=next_state;
always@(state,x_in) //This always block forms the next state
case(state)
S0:if(x_in==2'b01) next_state=S1;else next_state=S0;
S1:if(x_in==2'b01) next_state=S2;else next_state=S1;
S2:if(x_in==2'b01) next_state=S3;else next_state=S2;
S3:if(x_in==2'b01) next_state=S0;else next_state=S3;
endcase
always@(state,x_in) //This always block forms the output
case(state)
S0: y_out=2'b00;
S1: y_out=2'b01;
S2: y_out=2'b10;
S3: y_out=2'b11;
endcase
endmodule
This block takes the clock as input signal
input clock,reset;
It doesn't generate any clock signal, therefore you cannot control the input signal in this block. Think you need to control the freq of the clock from your FPGA bord,
Or the another workaround for you is to change this module description, like generate other clock in this module and use as your main clock. To do this you can use the below code
reg [2:0] cnt; // count the clock cycles
reg clk_delay; // delayed clock, this is the delayed version of input clock signal
always ( @posedge clock or negedge reset)
begin
if (reset==0) cnt<=3'b0;
else cnt <= cnt ==3'd5 ? 3'b0 : cnt+1;
end
if ( reset == 3'b0)
clk_delay <= 1'b0;
else
clk_delay <= cnt ==3'd5? clock : clk_delay;
( have not tested, but think will work)
