Bijesh Kawan
Newbie level 5
can you guys help me which analog pins are used for analog reading for the voltage,current,speed,temperature. and for respective relay driveres
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 #include<pic.h> #define ent1 T1CON=T1CON|0b00000111 #define dist1 T1CON=T1CON&0b00000110 #define load RB3 #define motor RB0 #define heater RB2 #define pump RB1 //enable timer1 //disable timer1 int convert[16]='0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'; unsigned int x,temp,adc_value,countdata,digit1,digit2,digit3,digit4,digit5,voltage,current,tem perature,level,speed; void timer_config(); void timer_read(); void control(); void hextobcd(); void acd_config(); void adc_data_accure(); void acd_read(int); void delay(int); void main() { TRISA=0xFF; // PORTA is input TRISC=0xFF; // PORTC is input TRISD=0x00; // PORTD is input TRISB=0x00; // PORTB is output 18 PORTB=0X00; TXSTA=0b00100100; RCSTA=0b10010000; SPBRG=25; voltage=0; current=0; temperature=0; level=0; speed=0; load=0; motor=0; heater=0; pump=0; acd_config(); timer_config(); delay(50); while(1) { voltage=0; current=0; temperature=0; level=0; speed=0; TMR1L=0x00; TMR1H=0x00; ent1; for(x=0;x<=100;x++) { if (RCIF==1) { control(); //configure serial port //configure serial port //Clear timer1 //Clear timer1 //enable timer 1 19 } delay(50); } dist1; //disable timer 1 speed=TMR0; timer_read(); speed=(temp*12); for(temp=1;temp<=30;temp++) { acd_read(0); temperature=adc_value+temperature; acd_read(1); level=adc_value+level; acd_read(2); current=adc_value+current; acd_read(4); voltage=adc_value+voltage; delay(1); } voltage=(voltage/30); current=(current/30); temperature=(temperature/30); level=(level/30); TXREG='F'; delay(100); temp=voltage; hextobcd(); TXREG=convert[digit3]; delay(100); TXREG=convert[digit4]; delay(100); TXREG=convert[digit5]; delay(100); 20 temp=current; hextobcd(); TXREG=convert[digit3]; delay(100); TXREG=convert[digit4]; delay(100); TXREG=convert[digit5]; delay(100); temp=temperature; hextobcd(); TXREG=convert[digit3]; delay(100); TXREG=convert[digit4]; delay(100); TXREG=convert[digit5]; delay(100); temp=level; hextobcd(); TXREG=convert[digit2]; delay(100); TXREG=convert[digit3]; delay(100); TXREG=convert[digit4]; delay(100); TXREG=convert[digit5]; delay(100); temp=speed; hextobcd(); TXREG=convert[digit2]; delay(100); TXREG=convert[digit3]; delay(100); TXREG=convert[digit4]; delay(100); 21 TXREG=convert[digit5]; delay(100); } } void control() { temp=RCREG; if(temp=='1') { load=1; } else if(temp=='2') { load=0; } else if(temp=='3') { motor=1; } else if(temp=='4') { motor=0; } else if(temp=='5') { heater=1; } else if(temp=='6') { heater=0; } 22 else if(temp=='7') { pump=1; } else if(temp=='8') { pump=0; } else { delay(10); } if(OERR==1) { SREN=0; temp=RCREG; temp=RCREG; CREN=0; CREN=1; SREN=1; } delay(100); } ////////////////////////////////////////////////////////////////////////////////////////// void timer_config() { T1CON=T1CON|0b00000110; //configure timer 1 as counter to count frequency //OPTION_REG=0b0010000; //configure timer 0 as counter to count frequency } ////////////////////////////////////////////////////////////////////////////////////////// void timer_read() { temp=TMR1L; temp+=(TMR1H<<8); } //collect TMR1L value //collect TMR1H value and add with TMR1L value 23 ////////////////////////////////////////////////////////////////////////////////////////// void hextobcd() { countdata=temp; countdata=(countdata/10000); digit1=countdata; countdata=(countdata*10000); temp=(temp-countdata); countdata=temp; countdata=(countdata/1000); digit2=countdata; countdata=(countdata*1000); temp=(temp-countdata); countdata=temp; countdata=(countdata/100); digit3=countdata; countdata=(countdata*100); temp=(temp-countdata); countdata=temp; countdata=(countdata/10); digit4=countdata; countdata=(countdata*10); temp=(temp-countdata); digit5=temp; } ////////////////////////////////////////////////////////////////////////////////////////// void acd_config() { ADCON1=0b10000001; ADCON0=0b01000001; delay(1); } ////////////////////////////////////////////////////////////////////////////////////////// void acd_read(int channel) 24 { if (channel==0) { ADCON0=0b01000001; adc_data_accure(); } else if (channel==1) { ADCON0=0b01001001; adc_data_accure(); } else if (channel==2) { ADCON0=0b01010001; adc_data_accure(); } else if (channel==3) { ADCON0=0b01011001; adc_data_accure(); } else if (channel==4) { ADCON0=0b01100001; adc_data_accure(); } else if (channel==5) { ADCON0=0b01101001; adc_data_accure(); } else { } } ////////////////////////////////////////////////////////////////////////////////////////// void adc_data_accure() { 25 delay(1); ADCON0=ADCON0|0b00000100; delay(1); adc_value=ADRESL; //collect ADRESL value adc_value+=(ADRESH<<8); //collect ADRESH value and add with ADRESL value } ///////////////////////////////////////////////////////////////////////////////////////////////////////////// void delay(int time) { int i,j; for(j=1;j<=time;j++) { for(i=0;i<=64;i++) { } } }
