Help me remodel UPS to increase its run time and complex power output
laxre_06
Junior Member level 2
i am planning to remodel a ups to increase its run time and complex power output too....
anyone can help me????
TC
Re: ups
To increase the UPS's running time you need to increase the size of battery ..
This can be done by adding an external battery ..
But bigger battery also means higher charging current, so you will need to look at the charging section of your UPS ..
Alltogether, this can be quite complex exercise ..
Try to post circuit diagram of you UPS ..
Regards,
IanP
    laxre_06
Re: ups
thanks...
besides on that, i also plan to re design its transformer.. how does it affect the whole circuit??
:D
Re: ups
If you replace the output transformer with one rated for higher power you will need to add (in parallel) a couple of power transistors, MOSFETS or BJTs, depending on what you already have inside .. see attached example ..
Regards,
IanP
    laxre_06
Re: ups
thanks a lot...
can i ask?
how could i exactly re design the transformer so that the running time of my ups will be lenghten and haver bigger complex power output?
Re: ups
I wouldn't re-design existing transformer .. You can't have more power out of it than it is rated for ..
Just replace it with bigger one ..
Regards,
IanP
    laxre_06
Re: ups
hmmm
sori..
what i mean pala is that i will make a low cost transfomer that will be use for my ups to increase its complex power output...
how could it be?
Re: ups
Maybe you can try to use transformer design sftware ..
Here is one example:
3.0 - Transformer Design
This next program is thanks to 'Particle' otherwise known as Geoff Sevart. With this, you can either analyse or design a transformer, although for proper design work you need to know a bit more than the program provides from its interface. Although fairly simple, it does give good results if you know what you are trying to achieve, and know some of the basics of the core material.
Regards,
IanP
